rim size
Old Mar 26, 2007 | 12:34 AM
makushr1's Avatar
Default rim size
What are the largest rims I can get for my 2007 a4 quattro with lowprofile tires without the wheels rubbing?
Old Mar 26, 2007 | 12:42 AM
akielb's Avatar
Default RE: rim size
you can fit 20's but then you will be buying new rims every time you hit a pebble in the road.
Old Mar 26, 2007 | 12:48 AM
makushr1's Avatar
Why is that? Would you suggest 18s then?
Old Mar 26, 2007 | 01:22 AM
Sleveke's Avatar
go for something which has a little bit of rubber around the rim to at least protect it if you hit a curb or get a flying rock at the rims. I think this is what he means.
Old Mar 26, 2007 | 03:37 AM
M3S2k's Avatar
I think 19's should be alright. I agree, 20's would probably work, but tires would have to be soo low pro a little pot hole or something will bend, or worse, crack a rim. 19's should hopefully leave you with enough sidewall to give you a little cushion.
Old Mar 26, 2007 | 04:05 AM
A4Rollin's Avatar
get 18s, and lower it. 19s are good but if you want a low effect to it, or planning on lowering it....get 18s. Alot of people notuie wheel rub with 19s, even more when lowering the car
Old Mar 26, 2007 | 05:03 AM
Flip's Avatar
I would suggest 18 and a nice lowering too. With 18's you can fit a nice lip and a thicker tire which will help with vibrations also.
Old Mar 26, 2007 | 08:03 PM
DavidTurbo's Avatar
My buddy has an 06 S4 and it came with 18's stock. I would at least go up to 19's preferably 20's. You can check on tirerack.com they will give you what tire size you would need fit 19's or 20's, if the tire is not too small I would definatly do 20's. His S4 came with pretty big tires, the B7's have a much bigger wheel well.
Old Mar 26, 2007 | 08:14 PM
akielb's Avatar
discount tire direct show's
zero available for 20's
only four wheels for 19's
I would say go with 18's for ride quality - if you lower the car and have super low-pro's then your going to have a crapy ride.
Tirerack.com has a lot more available for 19's. If you insist on 19's then I vote for 19's RS4 Reps
Old Mar 27, 2007 | 12:52 AM
M3S2k's Avatar
I know i am definitely leaning towards 19" RS4 reps for my B6 A4
Hecareth
Oct 14, 2009 10:59 AM
mystrodo
Sep 2, 2009 09:41 AM
flajoecool
Oct 24, 2007 07:02 PM
invincible569
Nov 18, 2005 02:43 AM
