RIM and TIRE QUESTION
Old Aug 21, 2004 | 08:38 PM
PandaXpress's Avatar
Default RIM and TIRE QUESTION
I drive 2002 A4 AWD with the sport package and i was wondering what is the widest i can go on the size of the rim in the rear and front
Old Sep 26, 2005 | 05:38 PM
silveraudi98's Avatar
Default RE: RIM and TIRE QUESTION
I was wondering the same
Old Sep 26, 2005 | 08:54 PM
juju4uofa's Avatar
Well, it depends on the offset. But I'd imagine 8.5" in front and 9.5" in rear. In my opinion wide rims on our car just adds unnecessary unsprung weight. With quattro I can see no instance where you would need more tire than an 8" wheel will handle.
Old Sep 26, 2005 | 10:02 PM
damn talk about someone bring up an old old thread of mine
ya they say 8.5 is the widest you can go in the front
since i have QUATTRO i would go wit 8.5 all around
damn i need wheels
Old Sep 26, 2005 | 10:13 PM
4dot's Avatar
why do you think you need 8.5 all the way around w/ quattro? as long as the circumfrence is the same on all four wheels there shouldn't be a problem.
Old Sep 26, 2005 | 10:15 PM
ORIGINAL: 4dot
no wut about the width of the wheel
18x9.5 will be heavier then 18.8.5 and that will effect the quattro system
Old Sep 26, 2005 | 10:36 PM
juju4uofa's Avatar
I disagree. The rear diff wouldn't be able to tell it's turnin a wheel 2lb. heavier than the front diff. Diameter is the only issue here, tire diameter that is.
Old Sep 26, 2005 | 10:43 PM
4dot's Avatar
ORIGINAL: PandaXpress
ORIGINAL: 4dot
i was referring to the width. correct me if i'm wrong, but the weight difference is so minimal that it would not matter unless the wheels were suspended. is the quattro system having to work harder in the back than the front? and don't they make alot of staggered wheels the same weight b/c of systems like quattro? what type of issue would that create in such a senario?
Old Sep 26, 2005 | 10:45 PM
headshok2002's Avatar
Tire diameter is the ONLY concern for quattro. That's it! Not weight, not colour, not ANYTHING.
Old Sep 26, 2005 | 10:53 PM
Yuikio's Avatar
ORIGINAL: headshok2002
He's right you know. There's a good technical reason, too, but I'm too lazy to look it up and too stupid to remember it.
