Rough Idel
Old Mar 21, 2007 | 01:27 AM
Mikesnewaudi7447's Avatar
Default Rough Idel
I have a 2001 A4 quattro love it to death. But ive noticed that the engine sounds a little rough when sitting idle. Its it because of the gas I use, I use89 not 91 but maby the 91 octane will make the diffrence? Thanks in advance
Old Mar 21, 2007 | 01:33 AM
Jeff's Avatar
Zombie Defense Force
Default RE: Rough Idel
1.8t or 2.8? use 91 or better. checked plugs, wires, maf? and cel codes?
Old Mar 21, 2007 | 01:41 AM
2.8
Old Mar 21, 2007 | 01:42 AM
Jeff's Avatar
throw some 91 in there and see what happens. get your car check through the obd2 port and see if you have any codes. check the spark plug wires, the spark plugs and make sure your maf is clean
Old Mar 21, 2007 | 03:07 AM
i2onnel's Avatar
I always use 91... I don't think 89 should be put in our cars...
Old Mar 21, 2007 | 03:12 AM
Flip's Avatar
The higher the octane thebetter. I always use 93 and up on my Audi but than again forced induction motors run more efficiently with high octane gas. With naturally aspirated motors it isn't as big of a deal but I would try some 91+. It could also be a number of other things like a vacuum leak or bad valve cover gasket.
Old Mar 21, 2007 | 01:16 PM
wolfdog's Avatar
I'd look into the plugs. My coppers went down to .038 from their original gap of .030. It took <10k miles and, once swapped for new ones, I noticed a difference in idle and response. You may not be using coppers but the same may be true even with platinums. If it's been a while, you may want to take a closer look at these.
Old Mar 21, 2007 | 03:12 PM
acetrebo's Avatar
Does it just sound rough? Can you describe the sound better?
Or is it running rough? Is the rpm jumping around and unstable? Does it run rough when driveing and not at idle?
Need some more info here, codes would be even better.
randos
Feb 14, 2013 09:26 AM
JBRoberts
Jan 10, 2009 08:57 AM
whitejeepXJ
Sep 26, 2008 06:46 PM
mdub
Feb 12, 2008 01:33 PM
awkishi
Sep 5, 2007 12:09 PM
