rough idle
Old Sep 15, 2005 | 05:37 AM
dab_master's Avatar
Default rough idle
So my car has been having troubles idling when its cold. i start it and its normal, idling at about 1200 and then it starts to die and it will rev its self to a little over 2400. then it starts to drop back to where its supposed to be, 1200, and the process starts again. i plugged it into an obd2 reader and got p1128 manufacturer control. fuel air metering. i was wondering if anyone knew what it could be. i dont have an audi dealer near me so i went to vw, and they said it might be mass airflow, which they have a recall for, or my o2 sensor. anyone know if audi has a recall on theirs?
Old Sep 16, 2005 | 12:48 AM
dab_master's Avatar
Default RE: rough idle
so does anyone have any ideas?
Old Sep 16, 2005 | 09:11 AM
david9999's Avatar
Year engine type, mileage and mods would be most helpful when posting questions regarding engine problems.
First thing I'd do is check for vacuum leaks and make sure that the gas cap is firmly twisted in place.
P1128
17536
Long Term Fuel Trim mult., Bank1
System too Lean 1)
2 Dcy
- Check HO2S -G39- and O2S control Page 24-17
- Check Oxygen Sensor (O2S)
- Check fuel pressure regulator and residual fuel pressure Page 24-93
- Check fuel injectors Page 24-87
- Output Diagnostic Test Mode (DTM) Page 01-42
- Check EVAP canister purge regulator valve output Diagnostic Test Mode (DTM), Page 01-42
jsweete
Jan 29, 2016 08:42 AM
rekabj1108
Apr 19, 2012 10:47 AM
justinclarke
Nov 25, 2010 04:03 PM
Swami51
Nov 4, 2008 05:08 PM
