Rough Idle 1999 A4 B5 2.8 L 30V AHA
Old Feb 26, 2005 | 07:16 AM
powerboat's Avatar
Default Rough Idle 1999 A4 B5 2.8 L 30V AHA
I checked pressure - all 6 are 220 psi.
New spark plugs.
Only error codes are random cyl. misfire, no engine check light.
Engine runs fine at middle and high speed. Only when idle it vibrates-misfires.
I believe it is an oxygen sensor, but again- NO error codes VAG-Com???
Any good thread to follow?
Thank you.
Old Feb 26, 2005 | 11:18 AM
Jestnomen's Avatar
6th Gear
Default RE: Rough Idle 1999 A4 B5 2.8 L 30V AHA
O2 sensors can cause rough idling. How many miles do you have?
Is the car jus vibrating, or are the RPM's fluctuating or both?
Old Feb 26, 2005 | 11:19 AM
david9999's Avatar
Clean the throttle body. One of the most common causes of staling or rough idle
Old Mar 3, 2005 | 05:13 PM
powerboat's Avatar
Ok, I replaced the primery oxygen sensors. They were bad.
The engine runs better, but still rough.
I run the car for 1/2 hour on the highway.
The Rediness Status for the engine now has the code: 0000 1100.
The bad fields are:
Secondary Air injection: Failed or incomplete;
Evaporative Emissions: Failed or incomplete.
What do I do next?
Thank you.
cesarnono13
Feb 4, 2011 11:55 PM
Bklynrx7
Dec 13, 2010 08:40 PM
justinclarke
Nov 25, 2010 04:03 PM
gubro30
Apr 16, 2008 07:20 AM
