rough idle
Old Nov 18, 2005 | 09:20 PM
septer612's Avatar
Default rough idle
Hello all,
I just bought a 97 a4 1.8 turbo awd. Everything was running fine and then I was just sitting in the car with it running and it just started idleing rough. The check engine light came on and then it stalled. Are a4s' notorious for anything weird? I remember reading about something that made them idle rough but I cant remember what. It has 100,000 miles on it. I would really appreciate any suggestions/info. Thanks
Jon
Old Nov 18, 2005 | 09:52 PM
onepoint8tee's Avatar
Default RE: rough idle
could be lots of things. Coil packs? They are notorious
Old Nov 19, 2005 | 07:56 AM
dankhound's Avatar
Ignition modules too. If its cylinder 2 misfire id bets its the module.
Old Nov 19, 2005 | 08:04 AM
Karl's Avatar
run a scan and see what codes you get..
Old Nov 19, 2005 | 12:20 PM
CRAZYHAWK's Avatar
My car had a similar problem last summer. Turned out to be a MAF. Best to get the car VAG-ed.
You might try disconnecting the battery, reconnect it, then turn the key part way. Do not start the engine for three minutes.
This sets the throttle body. It might idle then. You'll still have to fix the problem.
Old Nov 19, 2005 | 01:35 PM
Jestnomen's Avatar
6th Gear
Without the CEL code(s) we can offer you little if no help really. It could be hundreds of different things.
Old Nov 19, 2005 | 05:57 PM
david9999's Avatar
Agree, get the codes and post them. Could be anything from vacuum leak, fouled spark plug, MAF, coil pack or ignition module
jsweete
Jan 29, 2016 08:42 AM
rekabj1108
Apr 19, 2012 10:47 AM
justinclarke
Nov 25, 2010 04:03 PM
Swami51
Nov 4, 2008 05:08 PM
