Rough Idling????
Old Apr 16, 2012 | 05:27 AM
markcross76's Avatar
Default Rough Idling????
Hi Guys,
I have a 05 A4 1.8T Convertible that has recently developed rough idling. Additionally the emmissions light has come on and a garage has advised that fault code is saying that the mixture is too lean...
I have replaced all the plugs and also bought a new coil which I have tried on each cylinder but this has not stopped the problem. I am relunctant to just buy a new lambda sensor on a whim due to the cost so thought it best to seek advice on the forums in case there is another possible cause I could try...
Guys any advice on this would be appreciated or anyway of testing my current lambda sensor?
Many Thanks
Mark
Old Apr 17, 2012 | 09:47 PM
ImTheDevil's Avatar
Post the actual code(s) pulled from your ECU and we can narrow it down.
Old Apr 17, 2012 | 10:06 PM
milan2k12's Avatar
System too lean... is there oil in the coils/plugs? your head gasket might need to be replaced.
Old Apr 18, 2012 | 03:54 AM
Hi Guys,
The actual code is P0171 system 2 lean. When I replaced the plugs there was a small amount of clean oil halfway down one of the coils (on the outside) on the engine body but it did look very clean and would put it down to a spillage when topping up!
Hopefully the code about will point to he cause and this ain't a head gasket, the car has only done 42k and is very clean...
Thanks
Mark
Old Apr 18, 2012 | 08:35 AM
milan2k12's Avatar
System too lean usually means that you have a vacuum leak or even a PVC leak...there are many ways to test these leaks just youtube it.
if you are getting too much oil in your coils/plugs then you might want to to replace your head gasket valve cover.
Old Apr 30, 2012 | 08:01 AM
Default Resolved
Guys,
Just a quick note to let you know that this problem has now been resolved, there was a problem with a one way valve (not sure what it is called) that sits at the back underneath the injectors.
It cost £7.65 from Audi and instantly the problem was resolved.
Mark
bobo79
May 13, 2012 10:18 PM
bumere46
B7 Models
Jun 8, 2011 08:49 AM
a6showingage
Apr 1, 2008 06:12 PM
acollicott
Jan 9, 2008 11:49 PM
basilgreek
Apr 4, 2006 09:38 PM
