Running rough, loss of power
Old Jun 18, 2007 | 10:46 PM
stefano5's Avatar
Default Running rough, loss of power
Don't know what's happening starts running rough then CEL comes on I also noticed popping,burbling coming from exhaust. Not making power, missing, boost is not entirely thereeither, this is first for me ran great for 97,000 miles. I have to hook it up to Vag comp. but has anyone else experienced this?
1998 1.8t
giac 1bar
h&r springs
beilstein shocks
neuspeed exhaust downpipe
cold air intake w/ heat shield
n75 race
turbo inlet slicone hose
euro spec lights
forge diverter valve
Old Jun 18, 2007 | 11:58 PM
onepoint8tee's Avatar
Default RE: Running rough, loss of power
Could be a misfire if the CEL is flashing. Get your ecu scanned. There isnt much to discuss until you get the fault codes read.
Old Jun 19, 2007 | 01:18 AM
stefano5's Avatar
your right must do asap. do you think i can drive the car in the mean time, need transportation, until I get my hands on a scanner.
Old Jun 19, 2007 | 01:21 AM
jojoampt's Avatar
just happened to me, bad coil pack probably. like 40$ for one but i replaced all four.
Old Jun 19, 2007 | 02:13 AM
stefano5's Avatar
I was having a little problem starting it. It would not start the first time I turned the key but it woud the second. This would happen intermitenly was thinking that something is not firing right. We will see tomorrow.
Old Jun 19, 2007 | 08:16 AM
EJ30157's Avatar
Get the code scan at Autozone. Then post your codes. Most likely misfire due to coil pack and if you're replacing all the coil packs, replace spark plugs as well.
Old Jun 19, 2007 | 08:51 AM
stefano5's Avatar
code p0301 misfire in #1 cylinder, how do i check to see if it is the coil?
Old Jun 19, 2007 | 09:33 AM
rbrtech's Avatar
the easiest way is to sitch it with a diffrent coil from another cylinder and see if the misfire moves. This only works if you have access to a scan tool though. You can ohm it but not sure what the specs are of hand. More than likely it is coil or icm. Cheaper route is try a coil and do a tune if you havent already.
Old Jun 19, 2007 | 10:49 AM
EJ30157's Avatar
I'm betting that its your coil pack sinces it's only one cylinder misfiring and not your icm. I would replace all of them if you can afford it. Should be $130 for all four at ECS tuning. There are write ups on how to check the icm if you want to make sure it's not the module.
Old Jun 19, 2007 | 11:42 AM
stefano5's Avatar
changed the coil pack all the spark plugs put in iridium. Still have the same problem. I have to check icm. what is it?
