Running rough, loss of power
Old Jun 19, 2007 | 11:53 AM
acetrebo's Avatar
Default RE: Running rough, loss of power
ICM is on top of the airbox, under the cover.
If your misfire is in cylinder 2, that is your problem.
Old Jun 19, 2007 | 11:54 AM
stefano5's Avatar
all the plugs weredirty by the way but especially the #1. Plugs were not old maybe 20k on them at most.
Old Jun 19, 2007 | 11:58 AM
onepoint8tee's Avatar
ORIGINAL: stefano5
changed the coil pack all the spark plugs put in iridium. Still have the same problem. I have to check icm. what is it?
Did you get rescanned for fault codes? If you didnt have the cyl. 1 misfire cleared, it will still show up. If all you did was move a bad coil pack from cyl. 1 to a different cylinder, the problem will persist. You have to get the ecu rescanned to see if the misfire followed the coil pack.
Old Jun 19, 2007 | 12:02 PM
stefano5's Avatar
installed new coil.
Old Jun 19, 2007 | 12:10 PM
Duh, sorry I totaly missed when you said that. You are saying that you replaced cyl. 1 coil pack and you are still getting a cyl. 1 misfire fault code??? If you replced the plugs and coil pack, the only other things it could be is the ICM, bad head gasket (not likely), or the coil pack harness/wires. Im betting ICM, but like ace said, a cyl.2 misifre goes hand in hand with a bad ICM so I dunno.
Old Jun 19, 2007 | 12:24 PM
fahquad's Avatar
On mine, I had to swap out all four because they were all about to go even though I got misfire code for one cylinder. Seems like with coilpacks, when it rains, it pours. I swapped out one, and then they went in succession after I'd swap out the next.
I hate to be the one who brings up the "idiot check", but sometimes we all forget the dumb stuff.... so, you did check gap on all plugs?
[align=left] [/align]
Old Jun 19, 2007 | 12:45 PM
ironman's Avatar
If all of your pluggs were foiled i would check to make sure the injectors arent clogged its easy to pull out ther are DIY's jsut search or you can try to clean your plugs either way worth a shot.
Old Jun 19, 2007 | 01:24 PM
  #18
stefano5's Avatar
Yes, checked plug gap going to run a check on everything else we can think of, like onepoint8tee said "DUNNO". Maybe if I threaten to sell it might start running correctly. Its worked before. Thanks for all your help will keep ya posted on what happens with this "mystery missfire".
Old Jun 19, 2007 | 01:49 PM
  #19
rbrtech's Avatar
I have icm with just 1 cylinder acting up most of the one i have run into is cylinder 3. Anyway injectors could also be a cause. I bet on the icm though
Old Jun 19, 2007 | 09:25 PM
  #20
stefano5's Avatar
icm seems to be problem checked injectors checked plugs again rescanned then checked icm it seems my cousin "mechanic" its not completing the loop or something. I get stumbed when it comes to the electrical end of things so tomorrow getting new icm. Should solve the problem and back on the road we go.
dgerjets
Feb 26, 2015 11:28 PM
Dooley12
Feb 23, 2014 04:47 PM
AWD_Addict
May 2, 2011 01:04 AM
rescuer3
Oct 10, 2009 01:22 AM
doomwalrus
May 9, 2009 11:37 AM
