Running rough, loss of power
Don't know what's happening starts running rough then CEL comes on I also noticed popping,burbling coming from exhaust. Not making power, missing, boost is not entirely thereeither, this is first for me ran great for 97,000 miles. I have to hook it up to Vag comp. but has anyone else experienced this?
1998 1.8t
giac 1bar
h&r springs
beilstein shocks
neuspeed exhaust downpipe
cold air intake w/ heat shield
n75 race
turbo inlet slicone hose
euro spec lights
forge diverter valve
1998 1.8t
giac 1bar
h&r springs
beilstein shocks
n75 race
euro spec lights
I was having a little problem starting it. It would not start the first time I turned the key but it woud the second. This would happen intermitenly was thinking that something is not firing right. We will see tomorrow.
the easiest way is to sitch it with a diffrent coil from another cylinder and see if the misfire moves. This only works if you have access to a scan tool though. You can ohm it but not sure what the specs are of hand. More than likely it is coil or icm. Cheaper route is try a coil and do a tune if you havent already.
I'm betting that its your coil pack sinces it's only one cylinder misfiring and not your icm. I would replace all of them if you can afford it. Should be $130 for all four at ECS tuning. There are write ups on how to check the icm if you want to make sure it's not the module.
