Safe Boost and Rough Power Levels
Old Jan 16, 2006 | 10:51 PM
badassb5's Avatar
Default Safe Boost and Rough Power Levels
If I was to run roughly 13-14 PSI through my stock turbo would that be safe for daily driving while maintaining reliability. Also what would the power outputs be roughly?
Old Jan 16, 2006 | 10:52 PM
onepoint8tee's Avatar
Default RE: Safe Boost and Rough Power Levels
Depends on how you plan on achieving that boost. A chip is the most reliable/make sense way. If your thinking boost controler-forget it.
Old Jan 16, 2006 | 10:58 PM
trailboss's Avatar
CHIP > MBC.
The only other way really to up the boost is a MBC or a EBC and they don't add the extra fuel or ignition timing to safely run the extra boost.
Chips will normally run in the 200hp range, thats CHP.
Old Jan 16, 2006 | 11:20 PM
FASTER's Avatar
Tech Slut
the apr chip peaks your k03 at 17.4psi very reliably. new n75 valve will give a little raise too, but i wouldn't recomend it till other mods are done. i'm looking for the right n75 to compliment my other mods right now.
Old Jan 16, 2006 | 11:21 PM
badassb5's Avatar
I thought the APR chip peaks the boost at 14.7 not 17.4?
Old Jan 16, 2006 | 11:23 PM
trailboss's Avatar
APR chip should be 1.1 bar same with GIAC, 1 bar is 14.7
Pbcrazy
Apr 10, 2013 10:52 AM
chosos
Jul 7, 2007 02:43 PM
MC Hammered
Aug 25, 2006 02:12 PM
Ricardo_gn
Jul 14, 2006 11:21 PM
thizzwatitiz
Apr 30, 2006 07:29 PM
