seafoam in gas tank?
Old Jul 3, 2007 | 05:26 PM
x650rwc650x's Avatar
Default seafoam in gas tank?
hey everybody i just put seafoam in my crack case and did a oil change my car runs way smoother now and rpm seem to be free runs great. i didnt put it in my gas tank. but really want to clean out my fuel system and think it coulld help take that tick tick tick sound away right? so i already did the oil change if i put seafoam in my gastank do i got to change my oil again???????
Old Jul 3, 2007 | 06:01 PM
auditech79's Avatar
Default RE: seafoam in gas tank?
You shouldn't have to change the oil again if you put seafoam in the gas tank.
Old Jul 3, 2007 | 06:06 PM
SAudi's Avatar
no, the gas does not go in your oil system. also that tick tick noise is normal, apparently its the injectors going. loudest injectors ive ever heard.
Old Jul 3, 2007 | 06:15 PM
auditech79's Avatar
ORIGINAL: SAudi
Actually seafoam is quite effective in the oil, you just can't drive more than a couple hundred miles with it in there.
Old Jul 3, 2007 | 08:30 PM
A4 Effort's Avatar
I just dropped Seafoam in my gas tank without doing the oil, and i noticed a marked improvement in my throttle response after about 40 miles. I want to do the oil next.
Old Jul 3, 2007 | 08:52 PM
auditech79's Avatar
ORIGINAL: A4 Effort
If you wanna know what the absolute best thing to clean out your oil system is, forget the seafoam in the oil thing and drain the entire crank case of oil. Remove the oil filter and install a new one, fill the engine with Marvel mystery oil and run it for about 1 hour. Drain it and change the filter again.
I don't know whats in that s*** but ive never seen a better improvement in idle quality on any engine than doing that.
Old Jul 3, 2007 | 09:42 PM
A4 Effort's Avatar
Just looked it up; i've seen that stuff before.Do you just run 1 gallon? I figured that would be enough if it's only in the engine for about an hour.
Old Jul 3, 2007 | 09:58 PM
auditech79's Avatar
Thats enough for a 1.8T not a V6.
Old Jul 4, 2007 | 11:17 AM
SAudi's Avatar
ORIGINAL: auditech79
ORIGINAL: SAudi
i know what i meant was the seafoam wont get into the oil from the gas lines. ive already done the seafoam in the crankcase, vac lines and gas tank it is really the best bang for the buck when it comes to cleaning up the engine.
InvisibleFrisbee
Mar 31, 2011 11:00 PM
Audi_Girl85
Oct 28, 2010 05:31 PM
Diecast747
Aug 8, 2009 07:56 PM
Donz0r
Jul 31, 2009 11:05 AM
Texas_Pete
Apr 25, 2008 12:41 PM
