Service Light?
Hi, apparently, my car needs a In1 service. Does anyone know what kind of work is recommended for the In1? Also, my car needs a thermostat, are those reasonably priced? Thanks!
what incrament is this?
30k-air filter spark plugs
45k-trannie fluid
90k- timing belt, accessorie belt
and if you take it to the dealer they will be telling you about everything that is wrong. they will then hit you with a horrible bill if you go with it. as for a thermostat the part is cheap but quite a bit needs to be torn out to get to it so again the dealer will rape you. if you are not working on ur car your self find an indypendent mechanic that will be honest and good.
45k-trannie fluid
