Service Light?
Old Jan 24, 2006 | 03:01 PM
CaliA4's Avatar
Default Service Light?
Hi, apparently, my car needs a In1 service. Does anyone know what kind of work is recommended for the In1? Also, my car needs a thermostat, are those reasonably priced? Thanks!
Old Jan 24, 2006 | 03:25 PM
techbod's Avatar
Default RE: Service Light?
oil/oil filter/air filter/ plugs/ pollen filter/ timing belt and all parts/ coolant and thermostat/ break fluid-pads-disks the list is endless, depends on mileage/warranty
Old Jan 24, 2006 | 03:30 PM
sandman's Avatar
what incrament is this?
30k-air filter spark plugs
45k-trannie fluid
90k- timing belt, accessorie belt
and if you take it to the dealer they will be telling you about everything that is wrong. they will then hit you with a horrible bill if you go with it. as for a thermostat the part is cheap but quite a bit needs to be torn out to get to it so again the dealer will rape you. if you are not working on ur car your self find an indypendent mechanic that will be honest and good.
Old Jan 24, 2006 | 05:46 PM
CaliA4's Avatar
My car just hit 129K...the trans was serviced 3K miles ago, I just got a timing belt last month...
Old Jan 24, 2006 | 06:10 PM
Jestnomen's Avatar
6th Gear
It's just an in spection light. Doesn't mean anything is wrong. Please search the forums next time. Thats a VERY common question.
Truthteller
May 2, 2008 10:20 AM
Lena
Dec 15, 2006 09:59 AM
impaler2383
Dec 8, 2006 06:10 PM
Rikter
Aug 20, 2006 08:48 PM
audisales
Sep 7, 2004 12:15 PM
