Several problems for x-mas!
Old Dec 25, 2010 | 05:20 PM
ChrisSparky's Avatar
Default Several problems for x-mas!
Problem 1 - Car starts to shake at random times becoming more and more common. Engine light does not flash, I usually pop it into neutral and park it and wait 2-10 min for car to stop shaking. Mabey it's a coil pack?
Problem 2 - Car was idling around 1100 rpms and was shaking while idling. Now car is no longer shaking while idiling and runs at 900 rpms now.
Problem 3 - Car feels like it is underpower at sometimes, engine sounds normal and turbo sounds normal.
Car Info.
2004 Audi A4, quattro, sports package 1.8T. 140,000 km. Just had third cylinder mis-firing, got coil pack changed. Ran fine for 500km engine started to shake random times along with cel flashing.
Old Dec 26, 2010 | 09:34 PM
Update - When the car shakes the exaust sounds like it has something stuck in it, almost coughing. Also took a look under the hood while it was shaking and the engine was shaking from side to side.
Old Dec 26, 2010 | 10:56 PM
Dida bit of research on faulty valve purge
into it and it does sounds it failed while open. Depending on how it failed, it usually is one of two different symptoms. Both will turn on the check engine light, and store a code. If the valve fails in the stuck open position, the engine will run rough and not idle correctly.
Smokin Tubes
Feb 5, 2012 10:11 AM
mykien23
Dec 2, 2011 08:55 AM
redrhino
Oct 26, 2011 03:49 PM
commedecargons
Nov 9, 2005 06:43 PM
SamJamaica
Jun 13, 2005 02:07 AM
