short throw quick q's
Old Jan 17, 2008 | 06:05 PM
01afour's Avatar
Default short throw quick q's
i just got my ebay short throw in and just had a couple quick questions cause it came with no instructions. ive read the short throw install directions on audidiy and think i got the idea. my only questions are, all the little peices that are included (a spring, two plastic pieces, and some clips) are they just a replacement for the stock parts? the DIY i was looking at put all stock parts back in the car so im not sure what the extras are for. and also, it seems like theres 3 different heights i can set it at, is there any change made in the shifter depending on which its screwed into, i.e. shorter/ longer throw, shorter taller overall height ect. any help is appriciated because i will probably install this tonight or tommrow.
Old Jan 17, 2008 | 06:15 PM
Lazer Viking's Avatar
Default RE: short throw quick q's
all of that extra **** if for cars with push down reverse, you probably wont even use anything besides the ball, linkage connector, and shifter
Old Jan 17, 2008 | 06:20 PM
01afour's Avatar
i have pushdown reverse. is that bad?
Old Jan 17, 2008 | 06:23 PM
no it should still work
i think there is a writeup on how to install from b&m that works
or the one i used which is on audiworld
Old Jan 17, 2008 | 07:12 PM
qUaTtRoA4's Avatar
an eBay ss eliminates pushdawn reverse....which is why I went with stratmosphere....
should be an easy install....gl!
Old Jan 17, 2008 | 09:51 PM
01afour's Avatar
yeah im gunna try it tommrow. too effin cold out tonite.
AdamN
Feb 27, 2011 09:02 PM
ksuclipse
B8 Models
May 4, 2009 10:10 AM
zectasy
Jun 7, 2007 11:44 AM
theTTkid
Mar 29, 2007 09:35 PM
Mordendrak
Jan 4, 2005 10:51 PM
