Should my A4 beep with lights on & keys out?
Old Sep 24, 2005 | 07:18 PM
gsxr150's Avatar
Default Should my A4 beep with lights on & keys out?
I could swear when I first bought this car it beeped to remind me I've left the lights on. Now no matter what I try it's not beeping at me? Is is supposed to beep as a reminder? It's already the second time I've left my parking lights on... Or did I turn it off somehow by accident?
Thanks!
Old Sep 24, 2005 | 09:00 PM
david9999's Avatar
Default RE: Should my A4 beep with lights on & keys out?
It should beep when you open the door.
Old Sep 24, 2005 | 10:28 PM
gsxr150's Avatar
OK, yep...im pretty sure it worked a coupple weeks ago. Just for the last coupple of days there's nothing. Did I reset somthing? Or is there some trick to getting that back on?
Old Sep 24, 2005 | 10:31 PM
PandaXpress's Avatar
it only makes the noise when your door is open i have a 2002 A4
Old Sep 24, 2005 | 10:37 PM
gsxr150's Avatar
Just tested it again...no luck. Keys were out, door open, parking lights turned on. No sound. If there's no trick to it I'm sure warranty will cover it right?
Old Sep 25, 2005 | 10:12 AM
david9999's Avatar
If you are under warranty, have them take care of it. May just be some soft coding with a vagcom. Do your inside lights go on when you open the driver's door? If not, it may be the door switch.
Old Sep 25, 2005 | 02:39 PM
gsxr150's Avatar
Yep, lights work just fine. I wonder what the hell happended....
Anyhow thanks for the help!
Old Sep 26, 2005 | 07:28 PM
gsxr150's Avatar
Today I'm not sure what I did, but I parked and turned the key to the on postion. Then opened the door and it worked. There has to be some trick to turn it on and off.
Tremar
Jul 26, 2012 12:32 PM
MartinCieslak1
Sep 5, 2010 12:13 AM
shane@tm
Jun 18, 2010 11:16 AM
planetnb
Feb 29, 2008 04:57 AM
pathfinder184
Mar 19, 2007 07:49 PM
