Slight hesitation at idle/jerks under throttle
Old Apr 19, 2007 | 09:29 PM
viperu27's Avatar
Default Slight hesitation at idle/jerks under throttle
hi everyone, this is my first post here
although its my first post, i have tried to search for my problem extensively with no real results...perhaps im not putting in the right words in the search field.
anyhow, i have this 1998 a4 1.8t with 92k milesthats been giving me some problems. this does not happen all the time, but enough to need fixing.
at idle, the car starts to hesitate and then it jumps up to over 1k. then, when trying to accelerate, it hesitates and jerks even with the pedal all the way down. it progressively gets worse until i turn the car off, then turn it on again. i replaced the spark plugs thinking it would be the problem, but the problem persists. im wondering if its the fuel filter or a gunky throttle body. there is no cel comming on...what could it be?
thanks in advance for any replies!
Old Apr 20, 2007 | 12:11 AM
khj677turbo's Avatar
Default RE: Slight hesitation at idle/jerks under throttle
I have a relatively similar problem. No engine light codes, but took it to dicount or w/e and had them read and there was hidden a knock sensor code. That may be a cause for crappy engine output w/e, i just have to clean the sensor or replace it and then ill know, but from what i told it could be a cause.
Old Apr 20, 2007 | 01:44 AM
Vaudi's Avatar
Try unplugging the MAF sensor. See if it makes a difference.
Old May 6, 2007 | 02:05 AM
viperu27's Avatar
ok
i cleaned the throttle body, replaced the fuel filter, added some sea foam to clean the injectors and nothing helped...
it turned out to be the fuel pump relay that needed replacement. runs beautifulnow.
Old May 6, 2007 | 02:37 AM
less_of_me's Avatar
How much was the fuel pump relay? Did you do that yourself?
2001A6Canada
Dec 4, 2014 07:40 AM
NICKV
Mar 23, 2013 11:05 AM
gabeguimaraes
Feb 17, 2009 12:46 PM
Siren
Aug 8, 2008 09:41 AM
