Slipping Door...
Old Jun 2, 2006 | 04:42 AM
auDi1.8TQ's Avatar
Default Slipping Door...
After throwing the door shut a couple of times, I notice the door is tilt and uneven. When i close my driver side door it barely make it over the notch/hook to lock and close properly. How can i adjust the door without making it any worst, then what its is already.
Thanks for any advice or suggestions.
Old Jun 2, 2006 | 05:16 AM
auDi1.8TQ's Avatar
Default RE: Slipping Door...
any suggestion ppl?
Old Jun 2, 2006 | 11:43 AM
techbod's Avatar
fit new door pins if its loose if not you could open the door wide and jack it up a little to realign it you can also adjust the latch on the B pillar
Old Jun 2, 2006 | 06:40 PM
david9999's Avatar
It is either the door hinge (unlikely) or the latch (likely). The latch has screws to move it slightly up or down so that it closes properly.
Unsure how you could bend the hinges unless you had someone hanging on the door.
Old Jun 2, 2006 | 07:29 PM
north5995's Avatar
One of my doors does the same thing. I will try adjusting the latch.
audi guru
Jul 16, 2009 03:22 PM
bigern45
Feb 13, 2009 09:55 AM
vtraudt
Jan 9, 2009 10:51 AM
jello
Nov 5, 2007 10:32 PM
410ThirtyValve
Oct 25, 2006 10:37 AM
