Small dirt in valve bad??
Old Aug 22, 2005 | 12:45 PM
jimmysA4T's Avatar
Default Small dirt in valve bad??
Ok, I removed the intake manifold the other day and a tiny
amount of dirt (gravel crystals) fell into the cylinder valve.
I tried to vacuum them out and got some but still there is
a little left. I wanted to remove the motor but I don't want
to mess with the timing and the chain so is it ok if there's
a little dirt inside the valve? The valve is one that hits the
piston in the engine head.
I think it is dumb idea to put the bracket of the two sensor
for the vac hose under the maifold. Some german engineer
really sucks because that bracket could be placed somewhere
else that is more accessible! I wouldn't have to take off the
manifold and fuel rail and no dirt would have gotten into my
motor!
I'm planning to relocate the bracket to a different location. Is
that a problem as far as longer hose for some and shorter hose
for others?
Old Aug 22, 2005 | 01:07 PM
headshok2002's Avatar
Default RE: Small dirt in valve bad??
I think I know the hose you're talking about, and you don't need to remove the mani... just need some patience.
Old Aug 23, 2005 | 03:45 AM
lidonnit's Avatar
ORIGINAL: jimmysA4T
motor!
for others?
Are you talking like a real little bit or a tablespoon full? If it's only a few then it'll be fine. It'll get flushed to the bottom of the oil pan and sit there forever with all the little tiny metal chunks. It'll be cool.
Old Aug 23, 2005 | 04:24 AM
audiboy1618's Avatar
I once lost some ductape in number 2 cylinder, it was in my new block too. I was jacked to say the least.
Old Aug 23, 2005 | 04:26 AM
lidonnit's Avatar
ORIGINAL: audiboy1618
What were you doing?
Old Aug 23, 2005 | 06:13 AM
sandman's Avatar
hahaha, omg
Old Aug 23, 2005 | 06:17 AM
Every once and while i take things apart, just so happen i had the coil pack off, and was putting in new plugs that i had destroyed, and i had been doing alot of stuff, with a couple things on the top of the engine, and a small peice fell down. I tried to fire it up to see the cylinder would shoot it back up, all it did was put flames up through, still havent figured that one out.
Old Aug 23, 2005 | 12:26 PM
jimmysA4T's Avatar
I was trying to remove the intake manifold so I can
replace the vac hose. Didnt' clean the surface yet
that's why dirt fell in there while I remove the fuel
injector rail off the manifold.
There's not a whole chunk in there, just a few small
crystals of sand. Anyways, thanks for your inputs.
Old Aug 23, 2005 | 01:22 PM
lidonnit's Avatar
you'll be cool, dude. It'll be fine.. You have no idea how much crap there is in an engine. LOL ..... like duct tape.
Old Aug 23, 2005 | 02:04 PM
clconversion's Avatar
remove the intake manifold to repair a vacuum hose why ?
