Snub Replace
Old Feb 14, 2006 | 03:41 PM
avanttripleloop's Avatar
Default RE: Snub Replace
figure out what ,an easier way?.best of luck but cut corners can be costly.i think i'll start a new post of how everybody needs to have tha repair book.
Old Feb 14, 2006 | 05:25 PM
quattrosedan's Avatar
when i did mine....I jacked the car up and supported both sides with jackstands. Then I moved my jack under the oil pan....with a flat piece of wood between it and the pan and just supported the engine.....not really jack it up. Just get all of the pressure off of the mount. Then, if you look at the mount, there is a metal piece that stops you from pulling it off. You have to remove it....like three bolts....and some other stuff on the sides. I believe I had to remove the metal pieces going to both side mounts too, but they are easy. Just take off the two nuts and loosen the bolts in the rear. I believe I had to lower the ac compressor, 4 1/2 inch bolts, and remove the ac pulley.....two allen bolts. Then there was like two other bolts up top to remove and the mount along with the metal piece will come down. You have to use a little force to get the new mount up there, but it isn't that hard. I will try and take pics tonight and make a write up.
Old Feb 14, 2006 | 07:00 PM
mjvss21's Avatar
recieved my apr snub in the mail today, i think im just going to put it on when i do my timing belt, probably be the easiest right?
Old Mar 6, 2006 | 11:02 AM
toysa4's Avatar
well i have my poly snub mount. i am goin to try to put it intoday.
Old Mar 6, 2006 | 08:24 PM
toysa4's Avatar
well did my snub mount today it took me about an hour and a half. not too hard. old mount wasnt in bad shape but still wanted to replace.
Old Mar 6, 2006 | 08:35 PM
drkenan's Avatar
Mine took me about the same. It was hard getting it on but aside from that it works well. I was actually expecting it to feel a little better after reading all the hype.
surgeryman79
Mar 17, 2006 01:31 PM
drkenan
Jan 3, 2006 02:48 PM
onepoint8tee
Sep 19, 2005 04:49 AM
Dave666
Jun 24, 2005 01:10 AM
apg96
Jun 4, 2005 10:40 PM
