So i found out how to run unlimited boost...
Old Dec 19, 2007 | 10:45 PM
  #41
chaos92287's Avatar
Default RE: So i found out how to run unlimited boost...
should the n75 be plugged into the TIP? what about electrically?
Old Dec 19, 2007 | 10:46 PM
  #42
aRIf's Avatar
you can leave the n75 conencted electrically but no need to run any hoses.
Old Dec 19, 2007 | 10:52 PM
  #43
chaos92287's Avatar
the way i have it now, is it is plugged in electrically, its sitting in the TIP cause i dont want a hole, and the other 2 nipples on the n75 just have a hose going between eachother, so the n75 is basically just jerkin itself off
Old Dec 19, 2007 | 11:35 PM
  #44
Bogie's Avatar
did you pm Cincy? He runs a MBC and wrote up that diode DIY. If anyone here can help it would be him.
Old Dec 19, 2007 | 11:50 PM
  #45
chaos92287's Avatar
i figured he'd see this thread next time he comes on
i tried taking the n75 out of the TIP and put a bolt and clamp to plug the hole but it still wont work, everything seems to check out but i still can't get it to go past 5 psi. think the boost controller is broken? i had to soder the electrical connection between the controller unit and the control motor. should i check to see if its receiving power?
Old Dec 20, 2007 | 12:00 AM
  #46
Bogie's Avatar
I can't be of much technical help in this state, but maybe this will cheer you up:
https://www.audiforums.com/m_744306/tm.htm
scroll down for the pics.
Old Dec 20, 2007 | 12:25 AM
  #47
A4speed's Avatar
you might still have a code even though there is no CEL.
Old Dec 20, 2007 | 01:28 AM
  #48
AudiCross's Avatar
go to an autozone and have it clear the codes. there is a possibility you blew something. boost leaf or maby even ur turbo, although it isnt likley
Old Dec 20, 2007 | 10:07 AM
  #49
EliteTuning1's Avatar
ORIGINAL: Rhinop21
I beg to differ once the post count gets above 1000.
wow shut the *** up
Old Dec 20, 2007 | 07:00 PM
  #50
chaos92287's Avatar
reason why it wouldn't work is cause the ebc's step motor isn't working properly. so i hooked my n75 back up to the banjo bolt and wg but left the profec b still in my car and splitting the vacuum line between the fpr and intake mani cause i didn't think it would make a difference. i drove my car and now its holding 20psi and spiking 22-23 psi, it used to hold 16psi and spike 18-19psi.
the whole reason i got the ebc was to hold 20psi, but it didn't work, so i hooked my car back up the way it was originally, and now im holding 20psi...crazy[&:]
