Some Problems With My 96 A4 Need Help..
Old May 26, 2007 | 07:27 PM
xxdjdinot1989xx's Avatar
Default Some Problems With My 96 A4 Need Help..
[align=center]i just get my first car an audi a4 1996 and i have some problems with it but idk how much it would cost me around to fix.i was wondering if anyone here had the same problems and if you ever fixed them and how much was it around.
1st. im having alot of oil leaking from the front idk from which part but i know its in the front
2nd. im having a hard time steering when ever im driving slow i have a hard time turning its stiff.
3rd. i think my balljoints are mased up because its making noise when ever i sit in it and brake..
anyone with any info please help
thank you
[/align]
Old May 27, 2007 | 01:44 PM
wood_e's Avatar
Default RE: Some Problems With My 96 A4 Need Help..
1) Get under the car and check where its coming from
2) Check the power steering fluid level
3) Do you mean sitting still and hitting the brake?
Old May 27, 2007 | 02:17 PM
i went to shop today and they said its coming from the oil panel or something like that i guess the owner before me hit it and broke it so now its driping oil like crazy
2 no its when im steping on the brake whille driven
Old May 27, 2007 | 02:50 PM
techbod's Avatar
more info are you talking about the breaks/power steering/oil pan/sump leak??
Old May 27, 2007 | 11:11 PM
no my brakes are fine its just when i press on them i hear noise from my left side of the suspension and yeah i think thats what its called the oil pan that part is driping oil and idk how much it would cost to replace
Old May 27, 2007 | 11:33 PM
ou2mame's Avatar
from the looks of it, i don't think you know a whole bunch about cars.. lol, but just so you know keep an eye on the oil level until you fix it cause if it empties you're f-ed
Old May 28, 2007 | 12:31 AM
SAudi's Avatar
if it the bottom of the oil pan, hit it up with some degreaser and let it sit, see were it drips, if it the bottom of the oil pan or on a flat surface, drain oil, get some JBWeld and apply mix, thats what i did when i curbed my car, for the ball joints what kind of noise, if the ball joints are gone there should be noticable movement in the streeing, also which ball joint, in the tie rod, the quadra link control arms. thats really the only things that got a ball joint on them, if not sure, lift up the side and jiggle the wheels and see if theres any play. lastly what the dilema with the steering, was there fluid or not.
Smokin Tubes
Feb 5, 2012 10:11 AM
mykien23
Dec 2, 2011 08:55 AM
redrhino
Oct 26, 2011 03:49 PM
commedecargons
Nov 9, 2005 06:43 PM
SamJamaica
Jun 13, 2005 02:07 AM
