Something I realized...
Old Apr 16, 2006 | 10:41 PM
InsaneHatter's Avatar
Default Something I realized...
My buddy just bought a 2000 A4, and I was looking it over. I see that his rear swaybar looks WAY smaller then mine (I have never upgraded it)
So I am thinking I have an aftermarket/upgraded rear swaybar on my car (from one of the previous owners)
I measured the swaybar and its .75" , which equates to ~19MM. The same size as a nuespeed. I dont see any neuspeed branding or any other branding on it. I did notice the bushings were dark red (I have had to lube them up)
Also the swaybar ends have 2 holes (for adjustability ?) Its on the farthest one out (loosest?)
Anyone have any insight?
Image for your pleasure
Old Apr 16, 2006 | 10:45 PM
PandaXpress's Avatar
Default RE: Something I realized...
im sure u have an after market one casue stock isnt adjustable
Old Apr 16, 2006 | 10:48 PM
hmmm, well i know sport fronts are same as aftermarkets (I dont have sport package) is there way to check to see if the front bar is hollow?
Are the fronts adjustable? I havent checked that. I wonder what swarbar has 2 holes and maroon bushings... also, the hole closer to the outside is that stiffler or loser?
Old Apr 16, 2006 | 10:52 PM
no the fronts arent adjustable
Old Apr 16, 2006 | 11:11 PM
I just checked and yea, the front only has 1 hole, but I see most aftermarket ones are the same way. The only products i see are nuepspeed the even resembles my swaybar ,but the bushings on neuspeeds are RED , maybe they got darkers as the months/year went on?
I still need an answer to which is stiffer. the outside hole or the inside???
Being that a swaybar is 100-200+ $$ this is making me happier!
Old Apr 17, 2006 | 01:14 AM
Slowb5's Avatar
ORIGINAL: InsaneHatter
you tell us...you got the options...
Old Apr 17, 2006 | 01:18 AM
inside setting would be more stiffer, and does ur car have sub frame reinforcements for the rear sway bars cause that a big issue wit u b5ers
lebaneseboy
Dealerships
May 17, 2010 05:28 PM
Ywdzohbi
Nov 1, 2008 01:09 AM
zat0rsk1
Aug 20, 2006 11:35 PM
