Spark plug help
Sorry cincy, your right, 5 bar comes with the kit. Ill try putting on the old n75. Do you suggest an adjustable fpr still? If i go with a mbc, tune down the boost, will the lower air temps help with my lean conditions?? Because the car has big misfires, but its also running like crap at 5psi.
ORIGINAL: turbo kraut
i know that running that high isn't good, and a fmic is probably going on this winter early spring........ but why would apr say a mbc is not good? would it help that much? or should i look into the adj fpr? or both all 3? i know the fmic but what about the rest?
and i am thinking i am boostying that high, i am still waiting on my podi pod and guage, right now i have an el chepo guage that seems to be right, -21 at idle
If your gauge is at 0 when the car is off, you should be fine. I hada cheapo gauge and it died. Found out that i was boost 3 psi more than i thought i was.... oops.
ORIGINAL: ThePaintballGuy
What do the iat's get up to temp wise normally?
Josh
Josh
see, i have heard, and i am no expert, but running just the n75 is like russian rulete..... running the n75 pluged in(no hoses) and the mbc is alot better......... my car does 0-60 in 6.5ish seconds, before the n75 so it can't have that much power loss can it?
so could i go witha 5 bar to lower my boost?
since i have an 01 with a k03 not ko4?
My mbc gave me throtle cut issues the entire time I had it, no matter how it was adjusted, but only at half throtle in 5th gear at speeds above 60mph. I would always get "Exceeded maximum torque limit" fault code and CEL. Now that Im trying to sell the car, I am just running the n75 and dont have to deal with that anymore. This would only be a problem on DBW cars. Other people have experienced it with different mbc's (bleed and ball/spring only), so beware.
I guess you missed my post from above.
