Spark plug help
Ok let me rephrase the question, should i go for a mbc or an adjustable fpr? Is the 5 bar sufficient if i have mbc hooked up, or should i just get the adj. fpr, or both?? Im going to try the old n75 but im too tired to do it tonight.
If you have misfires, youd have a blinking CEL w/fault codes. Adress that problem first, and change your plugs to a cooler plug such as NGK BKR7E. Thats what you should be using anyways if youre 20+ psi. Try an n75 J or H valve before a mbc if you are DBW and are running a k03/k04. The different N75 will decrease spikes and pretty much eliminate thepart throtlesurging effect that the stock n75 is sort of known for. I notice that my n75 holds boost longer than my mbc did, but boost isnt built as quickly as with the mbc.
Oh sorry I seeyou have an H valve, they are more aggressive than the J. You could try to find an H valve for testing, or a mbc.
If you tuely have misfires, figure that out before doing any fuel/boost tweaking though.. Some inexperienced people use the term "misfire" as a general term for "engine runs rough/vibrations" which could be something totally different.
to be honest with you my car spikes and runs the same with both n75's, so i don't think running the other n75 will help..... i don't really like the idea of running an mbc..... but would if needed
like i said the fmic will be coming this winter, got to get some funds straightend up
I sent my ecu in the mail. But to get it tuned down, should i just take it to anyplace with a dyno??
Also my car doesnt idle right, more or less runs like crap all the time, and misfires. Wil the MBC fix that? Or i should be looking into the Adj FPR
(im going to put in the old n75 and old ngk plugs soon see how it works but i have minimal hopes)
