Spark Plugs
Old Dec 23, 2007 | 01:54 PM
S_R_N83's Avatar
Default Spark Plugs
Time to replace my spark plugs that the dealer put in at the 80k service. (Said to replace in 40k miles and I'm about there.)
My question... obviously those aren't copper plugs, theyre platinum. Everyone says don't run platnium plugs in Turbo cars, but OEM plugs are platinum..
Now I know I could go with NGK bkr63, .032gapcopper plugs and have to change them alot, but can platinum ngk pfr6q plugs really be that bad for my 1.8t, esp. since theyre OEM??
Old Dec 23, 2007 | 02:03 PM
onepoint8tee's Avatar
Default RE: Spark Plugs
Copper is best for disipating heat and is the ultimate conductor for electricity. Boost=heat. But, the stock 7-10 psi aint no thang. Its when youre near 20 psi+ that youd want to consider copper and a heat range cooler plug than stock (BKR7E). Search, this topic has been beaten to death over and over.
Old Dec 23, 2007 | 02:10 PM
cincyTT's Avatar
I'm make believe
They are ~$8/set and last 15-20k miles, thats seems good by me.
Old Dec 23, 2007 | 02:11 PM
seerlah's Avatar
From cinytt (on other post): All 1.8ts should run the same gaps.
Spark Plugs
OE Plugs: NGK PFR6Q - .032" gap
For Stock Cars - .032" gap:
[ul][*]NGK BKR6E[*]Autolite 3923[*]Denso Iridium IK20[/ul]
For Chiped Cars - .028" gap:
[ul][*]NGK BKR7E[*]Autolite 3922[*]Denso Iridium IK22[*][/ul]
I prefer the ngk bkr6's and have used the autolites also, work fine aswell. Just get copper plugs and change them every 15-20k miles.
Old Dec 23, 2007 | 02:15 PM
S_R_N83's Avatar
15-20k before having to change copper plugs is not bad at all. I was under the impression it was a lot shorter than that. If thats the case, I'll def just get the NGK BKR6E plugs
Old Dec 23, 2007 | 02:23 PM
20k is a stretch. More like 10k and 15k at the most. But still.... Less than $8 for em.... Even if you changed em every 5k miles i'd be trivial.
Old Dec 23, 2007 | 02:32 PM
cincyTT's Avatar
I'm make believe
I change them every other oil change personally (10-13k miles). If you do it at ~15k, you end up spending less and getting another 5k miles out of 3 sets of copper vs one set of stocks.
Old Dec 23, 2007 | 03:02 PM
seerlah's Avatar
CincyTT, when I get my car chipped, how will the new spark plugs need to be torqued? 22ft/lbs?
Old Dec 23, 2007 | 03:40 PM
cincyTT's Avatar
I'm make believe
always 22ft/lbs
cwedholm1
Mar 13, 2010 11:47 PM
Eric_C
Dec 13, 2009 10:48 PM
hsbertiii
Jan 19, 2008 01:42 PM
domino877
Nov 28, 2007 09:09 PM
aerostatwv
Nov 22, 2007 07:20 PM
