speaker help
Old Jan 30, 2007 | 12:04 AM
b.hasz's Avatar
Default speaker help
when my volume was all the way down my back speaker made this weird buzzing noise, i turned my volume up quite a bit after it doing this for a while and then turned it down to see if it was still there and it was gone, is this something i should worry about or take it in if it comes back?
Old Jan 30, 2007 | 02:15 PM
brrman's Avatar
Default RE: speaker help
You heard thebuzzing noise when you were sending no sound to the speaker?
Sounds like it might be just a wiring problem (loose wire causing a buzz)
Old Jan 30, 2007 | 02:30 PM
sirfalconx's Avatar
Its could be loose wires like brrman said, but it can be a blown output on the back of the head unit, or moisture got into the speaker and caused corrosion in the connector. Both have happened to my Z32.
Do A4's come with a facotry amp? if so, that could be another culprit.
BTW: Nice Sig, thats cool stuff.
Old Jan 30, 2007 | 06:59 PM
b.hasz's Avatar
no i have two amps one powering my subs and one powering my speakers
Tourbo24
Jan 17, 2010 10:34 PM
JonnyOctagon
Jul 6, 2008 11:36 PM
muckdawg24
Nov 26, 2007 01:23 PM
kchao2000
Jan 13, 2005 08:34 PM
