Speed sensor
Old Sep 9, 2006 | 07:12 PM
Ian Hunt01's Avatar
Default Speed sensor
Having bought a code reader for my A4 and checking the codes I keep coming up with a speed sensor error. I have cleared the code and my auto box works fine for a short time then drops back into safe mode.
Anyone had the same problem? I have found the sensor and ordering one soon, are they easy to fit? and anyone esle had the same problem with there own auto?
Thanks
Ian
Old Sep 10, 2006 | 01:14 PM
dankhound's Avatar
Default RE: Speed sensor
Should be easy to replace it. Never heard of the speed sensor causing the trans to go into limp mode, but i can see a failed sensor causing that.
Old Sep 10, 2006 | 01:15 PM
dankhound's Avatar
When you have the sensor out use a flashlight and maybe a mirror to inspect the toner ring for damage. Also make sure the sensor is in all the way.
Old Sep 10, 2006 | 02:10 PM
Ian Hunt01's Avatar
Thanks for the reply. I cant reset the code anymore as it just keeps throwing up the same code and cant clear it so this time it looks like its shot.
I have taken out the sensor which is G38. It just twists out and I assume the magnet is inside the gearbox.
The pickup part of it pulls out and a oil seal O ring I cant seem to test it so I may just have to bit the bullet and buy one in the hope thats the problem. The sensor sits onto of the drive shaft.
Ian
bobbyenglish61
Aug 27, 2013 07:55 AM
Toms Ķiris
Sep 11, 2012 06:52 AM
slimty360
Jul 23, 2010 11:18 PM
neomaxddr
Apr 1, 2009 03:16 AM
