Squeek Squeek, control arms?????
Old Jun 12, 2005 | 04:38 PM
bhj0887's Avatar
Default Squeek Squeek, control arms?????
I have this annoying squeek. It sounds like it's comming from the rear pass. side. I assume its one of the CA's, because it seems to be a common problem on these cars.
If it's not the CA, what else would cause this?
Old Jun 12, 2005 | 05:31 PM
david9999's Avatar
Default RE: Squeek Squeek, control arms?????
Don't know, usually it is the front arms that are the problems. could be another bushing.
What makes the noise worse?
Old Jun 12, 2005 | 06:08 PM
Karl's Avatar
maybe a shock?? or both??
Old Jun 12, 2005 | 06:27 PM
BFlan2001's Avatar
when does it make he noise?
Old Jun 12, 2005 | 06:50 PM
rs's Avatar
rs
bushing or struts id say, push down hard a few times on the side that makes the sound, after 4-5 pumps, let go and see if it jiggles, or if it just stops, jiggle=bad strut
Old Jun 12, 2005 | 07:43 PM
bhj0887's Avatar
ill try that.
It doesn't do it always. Its actually for some reason usually in reverse, when the car is cold, sometimes in first when taking off after sitting for a while
Old Jun 12, 2005 | 07:50 PM
BFlan2001's Avatar
hitting bumps? turning? press down on each fender pretty hard and listen for the squeak. is it definitely a squeak or could it possibly be a high-pitched grinding? rear wheel bearings fail more often than rear control arms
TeeterTawter
Mar 25, 2008 08:19 PM
wisheson_stars
Mar 27, 2007 03:36 PM
taitum_00
Jan 19, 2007 08:04 AM
snobord99
May 20, 2006 01:26 AM
juice88
Aug 13, 2005 11:45 AM
