Stalling
Old Oct 11, 2007 | 02:25 PM
olly's Avatar
Default RE: Stalling
Dear all,
Pleasure to be here as a UK member - 1998 Audi A4 avant quattro 2.8 tiptronic 30V - 128k so far.. Been a great car - recently it has started to stall when idling in traffic - is wierd, does a bit of 'hunting', then just dies instantly. Upon turning the key to restart (no throttle required) it bursts back into life... My question is:-
Isthis problemmore likely to be :- a) Throttle housing needs cleaning; b) Idle control valve needs cleaning; c) MAF needs replacing or D) any other suggestions? Perhaps a vacuum hose is leaking a bit?
Qtn for Dave, another UK member - in your previous posting you said "Idle up system - by this do you mean the idle control valve?"
Respect to all, any help would be greatly appreciated! Olly
Old Oct 16, 2007 | 06:19 PM
olly's Avatar
Sorry dudes- really need an answer to this from somewhere, its driving me mad!
Dear all,
Old Oct 17, 2007 | 01:33 AM
david9999's Avatar
I still say dirty throttle body.
You can use the vagcom locator to find someone local who will lend you his (cost is usually beer), check for codes and post them back here.
In the interim, but some throttle body cleaner, spray it on the throttle body and butterfly valve working it back and forth, rub GENTLY with an old toothbrush, and wipe out the gunk with a dry cloth. See if that works before replacing parts.
Old Oct 17, 2007 | 09:26 AM
olly's Avatar
Top man, thank you david9999very much- I will have a go at this.. Am I stating the obvious here - presumably I need to remove the throttle body entirely in order to clean it thoroughly? I think I can manage this..
Old Oct 17, 2007 | 12:29 PM
oneg's Avatar
clean the eletrical contact points on the maf sensor, if its getting low signals it can happen as well. mine threw a cell at me though, so iduno =/. but you could try it, its simple and hasnt been listed yet.
Old Oct 23, 2007 | 06:03 PM
olly's Avatar
Guys - finally got my shareware VAG Com installed - codes thrown for the above problem -
16487
P0103
Mass or Volume Air Flow Circ High Input
35-10 Intermittent
P1857
Load Signal Error Message from Engine Contr.
35-10 Intermittent
What's my problem? Am guessing I need a new MAF !!
Any answers most welcome!! Olly
Old Oct 23, 2007 | 06:11 PM
CRAZYHAWK's Avatar
Try to get a remanufactured MAF. They are as good as new.
Old Oct 23, 2007 | 07:56 PM
  #18
ant41487's Avatar
i actually have the same codes coming up for my audi, i did a check on the MAF.
First i checked the voltage from the plug to the fuse, got a reading of .8-1.0, the diagnostic report told me it should be in the range of .3-1.07, so that means the fuse is ok
then i plugged the MAF back in and took off the rubber protector and checked pins one and two while idling the car, and bumping the rpms to 4000, got a reading of 1.7-3.05, normal reading range is about 1.5-3.4, so that means the MAF sensor is good
Next thing the book told me to do was to change the ECM, which actually makes some sense, since it isn't the MAF, and it is also throwing that other code at me which is something about the engine controller, anyone think this could be the problem?
Old Oct 24, 2007 | 01:45 PM
  #19
olly's Avatar
Hi Guys, thanks for all your input - I have finally resolved the problem - bought a new genuine Audi MAF, fitted it in 10 mins, now the car idles perfectly!!
Good luck everyone and thanks for all your help Olly
msantarpio
May 13, 2014 12:11 PM
DavidWNicholls
Apr 4, 2013 01:20 AM
fixer1270
Dec 24, 2005 07:05 PM
RJiRoC86
Dec 21, 2005 03:50 PM
brian_sullivan
Nov 29, 2005 03:07 AM
