stalling on startup...
the past couple mornings, i would go out to start my car to go to work... and it would start, then stall out almost instantly.... so i start it again and give it a little rev and it is fine... any ideas? Idle Air Control maybe?
also, i was wondering if there were any warning signs of a TB starting to go? i.e. noises, leaks anything?
When I had this happen the TIP was not connected to the turbo. But then again my wouldn't start even if I gave it a little gas. after you get some new gas - unplug your MAF see if it runs ok - then you'll know its either the MAF or the system is suckin in un-metered air
