Stereo Question
Anyone know if the wires coming from the headunit into the back speakers are high level or low level? My amp has both so I figured I could get around using a line level out converter.
I want to tap the rear speaker wires rather than taking the signal from the headunit since I will only be running an amp and sub.
Thanks!
Thanks!
Bose:
The low level runs from teh head unit tot he amp in the trunk which then sends a high level to all 4 speakers.
Non Bose:
High level from front L/R channel from the head unit. Low level back to the rear built in amp located in the drivers side rear speaker. Then there is a high level signal out of that mini amp runinng across to the other side rear speaker.
Non Bose:
