STILL Misfiring after new coil pack and plugs
Old Mar 17, 2007 | 12:00 AM
tractioncontrol's Avatar
Default RE: STILL Misfiring after new coil pack and plugs
Sorry I don't know much about 12v's so one coil for all six cylinders and you replaced it?
Old Mar 17, 2007 | 12:35 AM
brandons34's Avatar
ORIGINAL: breeze.12
Ive just been through all that. unplug your maf sensor see if it smoothes out, if it does, replce maf
whats a maf sensor?
Old Mar 17, 2007 | 01:14 AM
Mass air flow sensor by unplugging it the ecu goes into a closed loop program.I doubt it is theMAF.Check cylinders 2 and 3 for spark by removing the spark plug wire and plug from the cylinders and holding them close enough to make a good ground on the motor, the spark shouldarc when the spark plug gets close enough to create a ground, if not replace the wires. I was trying to figure out if it was a fuel problem with the rpm but I don't think it is.
Old Mar 17, 2007 | 01:55 AM
brandons34's Avatar
Earlier in the week I pulled an O2 sensor. Maybe that has something to do with it?
Old Mar 17, 2007 | 10:30 AM
david9999's Avatar
Probably, did you pull the one on the side you are getting codes? reconnect it.
Old Sep 10, 2007 | 04:54 PM
Frails's Avatar
Hi all. I was wondering what came of this? I just had my tranny rebuilt on a 2000 4.2 A6 becasue i lost reverse and now it's misfiring like crazy. Warms up very very rough and then CEL. If I'm driving, while making a turn I hit the gas and nothing for 2-3 secs, then it kicks in. I was going to replace the plugs but now you have me thinking it could be something else. Any suggestions?
Old Sep 10, 2007 | 05:51 PM
CRAZYHAWK's Avatar
Frails, have the codes read and post them.
Old Sep 10, 2007 | 07:02 PM
  #18
apr_a4's Avatar
ok, first of all dont fo running around and buying things.
what are the four strokes that require combustion to ocour
fuel/air
compression
combustion(spark)
exhaust
one of those is not happening
swap injectors from a diffrent cylinder and replace with the misfiring thats for fuel and air
do a compression test its okay if you dont know what its supposed to be you can do this the oddman out way check all of them and if its obviouisly off then youmighthave a pricy fix if itand to see if its itdoa test to make sure if its the rings thyeres a quick way just pour a little oil on theyre that should close the gap in theyre is a badcompression ring
spark we can give it the bennift of the doubt since you replace plugs and coil packs
exhaust well it cant be it because all the above steps would have to occour inorder for this to happen
Old Sep 10, 2007 | 08:20 PM
  #19
Dudek12's Avatar
My old a4 was doing the same thing. I needed to change the maf sensor and it worked great. I would def try and replace that. I had a local shop let me test a new one out to see if that was the prob try and find someone that will do that if you can.
Old Sep 11, 2007 | 11:22 AM
  #20
Frails's Avatar
Had the codes pulled...
P0300 Random Misfire
P0306 Cylinder 6 Misfire
P0307 Cylinder 7 Misfire
P1141 Load O2 Implausible Value
Any thoughts?
ADR3NALINE FIX
Jun 18, 2019 12:35 PM
Fusion
Apr 27, 2010 07:30 PM
Mr_GoodKat
Apr 8, 2010 01:15 PM
psx2dude
Apr 8, 2007 10:36 PM
d_maniac
Jun 2, 2006 01:06 AM
