Strange Clicking Noise From Rear of Car
Old Dec 30, 2005 | 03:12 PM
18T's Avatar
18T
Default RE: Strange Clicking Noise From Rear of Car
its sounding more like the same problem i have which is a bad wheel bearing. go get it checked out. its like 250 to fix. parts and labor i think.
Old Dec 30, 2005 | 03:21 PM
Raddue's Avatar
Well, I just got off of the phone with the head mechanic over at the Les Schwab my family has been going to for years. He said that wheel bearings generally makes a constant howling noise, no matter what speed I'm traveling at, but that it might be the axel. Either way it's about $200 total for parts and labor, axel or bearing. I'm trying to work out with some friends to get it over there before the day ends to get an inspection done.
If it is the axel, is it still alright to drive it around town for the weekend? I'm not going to be doing any long-distance driving or anything, but I really don't want to hurt the car. I'm sure you all understand.
Old Dec 30, 2005 | 07:06 PM
Raddue's Avatar
Okay, I just had it looked at on my lunch break. The mechanic there says that it seems to be coming from the front right wheel, but that the noise is so slight that he isn't even sure if it's the axle. He checked all of the CV boots and joints, and they are fine. I asked him about a wheel bearing, but he drove it around and said that a wheel bearing would make a completely different noise, especially when the car is turned sharply.
Old Dec 30, 2005 | 08:11 PM
18T's Avatar
18T
wheel bearing is a clik clik clik in rapid succesion. sounds like when you put a stick on the wheel spokes of a bike wheel while its spinning.. sorta like that.
do you get the sound at lower speeds?especially if you drive by a wall and you hear the echo?
Old Dec 31, 2005 | 03:56 PM
Raddue's Avatar
No, I don't get the sound at slower speed, it's only when accelerating quickly, usually from a stop but I get if I'm rolling onto a freeway as well.
Old Feb 9, 2015 | 10:47 PM
jdunham989's Avatar
Default differential rear clicking noise.
I've hd the same issue with a 05 Cadillac srx. Awd. I've replaced cv axles and wheerings all the way around, and still the same clicking persisted when I would accelerate hard. It turns out it was the rear differential and u joint had to be replaced, and it cured the problem. The cost for a job like this cost me around 400. Hope this helps.
o_a_ravi@hotmail.com
Aug 30, 2012 07:05 PM
PrincessBrat
Jun 18, 2009 04:38 PM
NickBroderick
Apr 26, 2009 10:11 PM
trippin13
Nov 17, 2008 05:00 AM
AteUrV8
May 24, 2006 11:14 PM
