Strange knock on deceleration in 2nd
Old Oct 29, 2006 | 08:28 PM
wood_e's Avatar
Default Strange knock on deceleration in 2nd
I've recently noticed a knock on my car when decelerating in 2nd. I'm thinking its a worn mount, or something to do with engine movement. Anyone have a better idea?
Thanks...
Old Oct 29, 2006 | 08:56 PM
Jeff's Avatar
Zombie Defense Force
Default RE: Strange knock on deceleration in 2nd
have some one rev it up while you look around the motor for any thing unusual
Old Oct 30, 2006 | 12:31 AM
wood_e's Avatar
Just revved it. No oddities, but that was sitting still obviously, in neutral...
Old Nov 1, 2006 | 02:08 AM
dankhound's Avatar
Only happens in second when decelerating? No other gears. Sounds like a bad coast side on the second gear set.
Old Nov 2, 2006 | 05:46 PM
wood_e's Avatar
Actually I have indeed noticed it in other gears now that I'm listening for it more. I hope its a mount or something... not the trans
Old Nov 3, 2006 | 01:49 AM
dankhound's Avatar
Does it knock once, or continually with the speed of the vehicle or engine?
Old Nov 3, 2006 | 04:10 AM
wood_e's Avatar
It knocks a couple of times, not in sync though with the engine speed, sometimes its like a knock... knock knock sound...
I'm going to jack up the car this weekend and check out the underside.
Old Nov 5, 2006 | 10:24 PM
wood_e's Avatar
Well the engine mounts look ok. Anywhere else I should look?
Old Nov 5, 2006 | 11:31 PM
AML 225's Avatar
I think the problem your describing is similar to the problem I'm experiencing. Sounds like something (probably the engine) is shifting. Mine does this on acceleration too.... Haven't had it looked at yet but I've been drivining with it like that for two months with nothing major hopefully just an engine mount.... :-(
Old Nov 9, 2006 | 03:26 PM
dxl2749's Avatar
did you also check your transmission mounts? mine was making a metal knocking sound on upshifts and downshifts as well as on bumps. the transmission mount was cracked and the two broken parts were banging together.
[IMG]local://upfiles/26216/00737AC6E1C34D4699E9CECF44F21A33.jpg[/IMG]
