Strange noise when starting car
Old May 15, 2007 | 03:21 PM
mikehinnenkamp's Avatar
Default Strange noise when starting car
Hi
I havea 1998 Audi A4 with about 150k on it. When i first start it, I ued to hear a noise that sounded something like an air pump or something. This would usually stop after a minute or so. Today, when i started it, it made a low whining noise and then started grinding.
Does anyone know what this noise could be? Its not the cooling fans, because they are stopped and i still hear the noise.
Thanks!!
Old May 15, 2007 | 11:38 PM
auditech79's Avatar
Default RE: Strange noise when starting car
Secondary air pump just died probably. It should sound kinda like a vaccum cleaner when you first start it.
Old May 15, 2007 | 11:47 PM
Yeah, I was thinking it was an air pump too. Anyone know where it is located and if I can just disconnect it? Or is it something that I should replace right away? It only runs for about 1 minute when I first start the car if its cold.
Thanks
Old May 15, 2007 | 11:53 PM
auditech79's Avatar
Its under the car on the passenger's side i think, you can just un-plug it but you will fail emmisions.
Old May 16, 2007 | 08:35 AM
ironman's Avatar
could also be condensor bearing going, i had mine fail on my last car, itll just grind away see if you can make any AC. If you can then its not that
Old May 16, 2007 | 08:53 AM
CRAZYHAWK's Avatar
ironman, did you mean compressor bearing?
Carnutter5
Aug 19, 2011 03:50 PM
Simonr501
Mar 9, 2008 08:10 AM
Simonr501
Feb 27, 2008 11:07 AM
bleuachdu
Oct 31, 2007 03:06 PM
TDRILL
Aug 20, 2007 06:12 AM
