synthetic oil
Old May 20, 2006 | 03:11 AM
melange_not_tan's Avatar
Default synthetic oil
Is it bad to go from synthetic oil back to regular oil. I've always thought in the long run, oils oil.
Old May 20, 2006 | 03:36 AM
A4PLAYIN's Avatar
Default RE: synthetic oil
..... not to sure, but i don't think it is.... i mean, why go back, synthetic is better for the audi's anyways, don't be a cheap a$$ about it.
Old May 20, 2006 | 03:57 AM
elvis12's Avatar
2.8 hummmmm
1.8t syn no questions asked
hell syn works better no q
spend the extra few bucks
E
Old May 20, 2006 | 03:59 AM
Trey25's Avatar
Over the long run synthetic oil is better for the engine. If your gonna spend thousands for your car then don't you want the best protection for your investment? Motor oil and high octane gas are things you should definitely not be stingy with. If so then get a civic.
Old May 20, 2006 | 04:33 AM
elvis12's Avatar
trey has got it
E
Old May 20, 2006 | 05:29 AM
BadLuckAudi's Avatar
its probably not a good idea to switch back and forth, i wouldnt, and you should stick with syn
Old May 20, 2006 | 05:36 AM
luvin_the_rings's Avatar
every heard of a term called leakdown?
cars with alot of leakdown get thier oil changed by jiffy lube and use regular oil
cars with sub 5% leakdown have been synthetic all thier life... over all just better for your engine
leakdown: the decrease of compression in an engine that results in a loss of power over a long period of time...
Old May 20, 2006 | 06:07 AM
flyboy's Avatar
ORIGINAL: luvin_the_rings
WHAT? thats like partly true. but I think you got the rest of that strait out of your ***.
But yeah, go with synthetic.
Old May 22, 2006 | 03:38 PM
ok. I just put synthetic in for the first time. I can already tell how much smoother the engine runs. Thanks guys.
Old May 22, 2006 | 03:50 PM
techbod's Avatar
standard oil is old stuff and not designed for the cars of today, full synthetic is for performance cars and those with money to waste ( well not actually wasting ),
semi synthetic can be mixed with standard where as you cant with full synthetic so if your not racing round the track semi is good,
standard oil is 25% gasoline based so it evaporates and causes sludging,
full synthetic is man made and withstands the riggers of heat and ware so best for high performance,
semi synthetic is a mixture of the best with extremely little of the old crap and best for the average drivers car
