Tach falls to zero, indicator lights flicker
Old Sep 7, 2005 | 01:21 AM
toolrocks's Avatar
Default Tach falls to zero, indicator lights flicker
My gf has a 99 A4 V6 and recently it has been acting strange. The car drives and idles fine but will occasionally do the following: the ABS indicator will light up solid, the tach will fall to zero, the brake indicator will flash and, the oil pressure indicator will flash. There is also a beeping that goes along with all this. Like I say, the car will still be running, the engine doesn't stall or stumble, the transmission will shift fine and everything else is as usual. After some time all the above symptoms will cease. I don't have a FSM or Haynes/Chilton manual for her car but intend to get one to help with the diagnoses. I called the dealer today and they didn't have a clue other than to $bring $it $in. Has anyone had a similar experience or know what I may want to check? Btw, there are no CEL/MIL's. Thanks for any input.
Old Sep 7, 2005 | 02:37 AM
david9999's Avatar
Default RE: Tach falls to zero, indicator lights flicker
Sounds like a loose ground connection in thedashboard
Old Sep 7, 2005 | 03:24 AM
sandman's Avatar
the tach rpms drop but the actual rpms dont? ^^^^yep, sounds like an electrical prob. hook er up and check for any codes then post them, autozone will do this for u for free.
Old Sep 7, 2005 | 05:21 AM
Karl's Avatar
hmm yeah if the engine isnt dropping in RPM's could be a number of things.. but if your RPM's drop it could be a bad alternator.. mine did that.
biocpu
Jun 29, 2015 01:10 AM
metalmelitia
Apr 24, 2015 08:03 AM
04A4Q
Jul 8, 2009 10:47 AM
liv2wrshp
Mar 19, 2007 12:18 AM
707782y
Mar 7, 2006 08:45 PM
