Temp sensor
Old Jan 10, 2007 | 03:43 PM
fcanozo's Avatar
Default Temp sensor
Hi guys,
I did change the temp sensor today because code P0118, everything is fine but false reading on the temp gauge, stays in 1st mark,.
Anybody please help?
Thanks
Old Jan 10, 2007 | 06:24 PM
onepoint8tee's Avatar
Default RE: Temp sensor
sticking thermostat... Can also trigger a temp sensor fault code. Cheap, but not as easy to replace.
Old Jan 10, 2007 | 09:37 PM
fcanozo's Avatar
I did replace it today, but since that it's reading like I just start the car on.
Help please!
Old Jan 10, 2007 | 10:08 PM
fcanozo's Avatar
No body?
thanks anyway!
Old Jan 10, 2007 | 11:37 PM
fcanozo's Avatar
Old Jan 10, 2007 | 11:50 PM
Trey25's Avatar
Bad ground possibly. Or just a bad gauge.
Old Jan 10, 2007 | 11:52 PM
ORIGINAL: fcanozo
Help please!
You said you replaced the temp sensor, not the thermostat. Are you saying you replaced both?
Old Jan 11, 2007 | 12:03 AM
fcanozo's Avatar
I did the thermostat 6 month ago w the TB, and today I replace the coolant temp. sensor because a code P0118 but after I did it, the temp. gauge is giving me false readings
Old Jan 11, 2007 | 12:06 AM
tractioncontrol's Avatar
When you say everything is fine do you mean the code is gone?
Old Jan 11, 2007 | 12:07 AM
fcanozo's Avatar
yes
