Temperature decrease
It should be either pink or purple. If you mix the oem fluid (G12) with different kinds such asPrestone yellow/green stuff,it can sludge up your system and probably cause a sticking thermostat.
Coolant drain is located on the drivers side on the lower part of the radiator. It is a little red screw thing. I think you have to remove the bumper to get to it. And I just noticed that you have a 03 and I am not sure if it's in the same spot as mine.
Josh
Josh
Prestone does have an antifreeze now that says it is compatible with all kinds of antifreeze. has anyone tested this yet?
I can't believe its like $14/gallon now. i remember when it was like$5 a gallon back in '99.
