Temperature decrease
Old Oct 29, 2007 | 01:16 PM
onepoint8tee's Avatar
Default RE: Temperature decrease
It should be either pink or purple. If you mix the oem fluid (G12) with different kinds such asPrestone yellow/green stuff,it can sludge up your system and probably cause a sticking thermostat.
Old Oct 29, 2007 | 01:17 PM
Audi_Skydiver's Avatar
Coolant drain is located on the drivers side on the lower part of the radiator. It is a little red screw thing. I think you have to remove the bumper to get to it. And I just noticed that you have a 03 and I am not sure if it's in the same spot as mine.
Josh
Old Oct 29, 2007 | 07:56 PM
tft003's Avatar
Mine does the same thing... Let me know when You get yours figured out! =)
Old Oct 29, 2007 | 09:12 PM
Bogie's Avatar
Prestone does have an antifreeze now that says it is compatible with all kinds of antifreeze. has anyone tested this yet?
I can't believe its like $14/gallon now. i remember when it was like$5 a gallon back in '99.
Parker0217
Nov 21, 2013 07:03 AM
peterbr17
Jul 10, 2009 06:59 AM
jostojic
Apr 15, 2009 10:36 PM
guy4graphics
May 19, 2008 10:59 PM
ricker
Aug 27, 2007 11:02 PM
