test pipe installed
Old May 23, 2006 | 07:57 PM
forcefedaudi's Avatar
Default test pipe installed
Installed atp test pipe.Fit good sounds good on stock exhaust and made the turbo sound like a diesel truck but ill never put one in again. The nuts on the turbo came off with no problem at all,the nuts on the back of the exhaust where so rusted and rounded they eventually had to be cut.
Old May 23, 2006 | 08:58 PM
Beer Mod's Avatar
Default RE: test pipe installed
Sounds like a pain did you use any penetrating oil?
Old May 23, 2006 | 09:45 PM
yup gave it a good soaking then let it cool for a while then sprayed everything again just to be safe.dam things wouldnt budge.
Old May 23, 2006 | 09:47 PM
KarlMarx's Avatar
So other than the fact that it was hard to disconnect everything from your turbo, you are happy with the test pipe?
Old May 23, 2006 | 10:02 PM
definetly,sounds great and you can feel the tourque.
Old May 24, 2006 | 11:29 AM
north5995's Avatar
This is something I want to do in the near future. I wondered about how the test pipes would fit up to the stock K03. So the fitament was ok up against the turbo?
Is this the one you purchased? http://www.atpturbo.com/Merchant2/me...Code=AUDIVW-DP
Old May 24, 2006 | 01:15 PM
germancarmaniac's Avatar
save the money and gut the cat. why spend the money when you dont have to?
Old May 24, 2006 | 01:31 PM
JohnnyBravoA4's Avatar
If you can wield you should make your own custom test pip and downpipe its really easy, and it will save you some big $$$
I Made mine, the test pipe and down pipe are one whole unit, looks tight made a huge difference..
Old May 24, 2006 | 03:30 PM
north5995's Avatar
Do you have pics of your custom contraption?
osin34
Jan 27, 2010 11:57 AM
cordaroa4
Aug 12, 2008 11:17 PM
CIA
May 14, 2008 04:46 PM
96audia4
Apr 2, 2007 01:09 AM
azaky
Feb 20, 2007 12:34 PM
