Theoretical Swap.
Old Sep 18, 2006 | 05:41 PM
MilitantGrunt's Avatar
Default Theoretical Swap.
Would it be possible to swap my 1.8T with a 2.0T out of a wrecked golf gti? The engine size and layout looks pretty similar, one really major difference is the addition of a another intercooler. The lifters in my 1.8T are making a lot of noise, it could be the wrong oil weight ( changed oil about 800mi ago) or it could be the fact that the engine is possibly giving out,if that is the case id possibly want to go for a 2.0T, get 200hp off the bat. Im just wondering weather or not this sort of swap is possible.
Old Sep 18, 2006 | 05:50 PM
SilverPullit's Avatar
Default RE: Theoretical Swap.
i dont think it would work because you would be going from a longitudinal to a transverse (or vice versa) motor. the layout would be different.
Old Sep 18, 2006 | 06:09 PM
the B7 A4's have the same setup, im just wondering how much would such an engine cost and weather it would hook up (putting into consideration that it is the correct format engine )
Old Sep 18, 2006 | 06:12 PM
PandaXpress's Avatar
the B7 has the same engine placement as the B5 and B6 which is longidutinal(sp)
while the golf, jetta and A3 TT have the transveral
if u got the money it might work
the B7 passat which is the same chassis as the A4 has a VR6 3.6 which is in set in the transveral position
but if u want to do a 2.0T sway get the A4 2.0T
Old Sep 18, 2006 | 08:42 PM
TomRitt's Avatar
mechanically it might be easy but how are u gonna program that thing
o0hmikee
Oct 24, 2011 10:19 PM
damo a4 quattro
Apr 18, 2009 12:18 PM
tomustang
Mar 20, 2007 11:19 AM
SKiTZo
Jul 8, 2006 10:29 PM
impaler2383
May 17, 2006 11:29 PM
