IS THERE A PROBLEM WITH MY TURBO, OR LEAK?
Old Dec 16, 2006 | 10:34 PM
98A498's Avatar
Default IS THERE A PROBLEM WITH MY TURBO, OR LEAK?
Hey i was wondering if this is normal or not. I have a 1998 audi a4 1.8t 5speed, the mods i have done are, APR 1 bar chip, FMIC, Intake, Baileys Motorsports DV, and exhaust. So here is the question: when i take off in first the boost goes up to 15psi but then starts to drop off fast before i have to shift to second, then when i shift to second the same thing happens the boost goes to 15psi and starts to drop of before i have to shift to third. It holds 15psi all the way through 3rd,4th, and 5th. Also the car feels slow for all the mods it only runs a 15.6, and my buddy has a 97 1.8T 5speed with just the chip running a 15.2.
thanks, Phillipe
Old Dec 16, 2006 | 10:40 PM
AudiCross's Avatar
Default RE: IS THERE A PROBLEM WITH MY TURBO, OR LEAK?
EDIT: i guessi should also say you can edo a pressure test. its in teh DIY section i think. or is there is a loud wshhhhhhh noise when you are accellerating, then thats prod a leak. or if the guage bounces around a bit it could be a bad n75 valve or a bad wastegate (what i think i have right now)
well i have a quattro with exaust and chip adn i ran 15.6 at best.
here it goess...
chipped boost should be 18-21 bdetween 3&4k. after 4k it should drop off to 10 ish by redline.
a lot of drags has to do with how well you drive also, so thats one.
Old Dec 16, 2006 | 10:44 PM
98A498's Avatar
Yeah, driving does have to do alot with drags but ive driven his car and ran a 15.3, so its not bad driving. Do you think the FMIC might be the reason im only getting 15psi and not 18-21, or might i have a boost leak.
Old Dec 16, 2006 | 11:27 PM
Lazer Viking's Avatar
if you got a crappy fmic, your pressure drop could be that much
Old Dec 17, 2006 | 02:18 AM
ThePapaCMan's Avatar
I dont think a crappy front mount would cause that great of a pressure drop, especially the way you describe it. I would agree with audicross and say that you have a boost leak or your wastegate is opening too early.
Old Dec 17, 2006 | 02:45 AM
NCAUDI's Avatar
I was having the same problems. Here is a test some guy wrote up that helped me find my leak. Good luck.
http://www.a4mods.com/index.php?page...boostleak.html
Old Dec 19, 2006 | 12:37 AM
98A498's Avatar
So i just got done doing a boost leak test but couldnt really find where my leak was, What i did hear though while i was compressing the air into the intake was oil bubbling. Does anyone know what this could be?
Octane567
Aug 8, 2014 10:28 AM
Gilly
Mar 22, 2013 05:59 PM
luis_16_r
Mar 30, 2012 08:07 AM
inventorA6
Apr 15, 2009 06:46 AM
xxjoshuapxx
Jan 20, 2007 02:47 AM
