Throttle position sensor limit too high
Old Jun 29, 2017 | 03:34 PM
winterdru's Avatar
Default Throttle position sensor limit too high
I was having problems with my fans not running so I started pulling relays too see if that was the problem and after putting everything back together I went to start the car and I had the epic light and traction control light on. After checking the codes I had throttle position sensor limit too high. I have replaced the throttle body and gas pedal assembly and still have the same code. I did the adaptation and still nothing. There is no response when I hit the gas pedal but when I hit the brake pedal and release it the car goes WOT. It is a a4 1.8t with a stage 1+ tune.
Peterhopson84
Aug 20, 2013 09:57 PM
audiA487
Mar 18, 2009 06:23 AM
IshTerp
Oct 30, 2008 12:05 PM
shelbyturbo
Oct 2, 2007 12:07 AM
audi_pa
Nov 4, 2006 09:39 PM
