tie rod ends replacement
Hi,
i need to replace my tie rod ends on both front tires. does anybody have any information on it? if anybody's done it before, i'd appreciate a tip or two to make like easier for me.
thanks.
-fahad
thanks.
-fahad
contol arms yes tie rod ends no also before I get in trouble it wasn't a recall on the arms either it was a service action the difference between the 2 a recall they have to replace somthing a service action theyonly replace something if something is wrong with that part
yeah the dealership told me about the alignment needed after the job.
thanks jetsnomem for the link to the audiworld article.
i'll try it out this saturday. hopefully the winter storms will leave cali by then.
Alright, I have attempted a tie rod replacement and ran into an issue. My tie rod required the arm puller for removal, it did not come out easy. The new tie rod does not want to go in, I have tried several angles, wiggling, and adjusted the distance between the lock nut.
Any suggestions for installing the new tie rod?
