tie rod ends replacement
Old Jan 11, 2005 | 05:39 PM
sdaudi's Avatar
Default tie rod ends replacement
Hi,
i need to replace my tie rod ends on both front tires. does anybody have any information on it? if anybody's done it before, i'd appreciate a tip or two to make like easier for me.
thanks.
-fahad
Old Jan 11, 2005 | 06:15 PM
audiboy1618's Avatar
Default RE: tie rod ends replacement
I would contact audi before you do it yourself, there was a recall on my mine.
Old Jan 11, 2005 | 06:18 PM
Jestnomen's Avatar
6th Gear
Are you wanting to do the service yourself?
Old Jan 11, 2005 | 07:31 PM
sdaudi's Avatar
mine is not up for a recall.
i'd like to do it myself. unless it requires some special tools or something?
Old Jan 11, 2005 | 07:54 PM
clconversion's Avatar
the tie rod ends were never on a recall for the a4's
Old Jan 11, 2005 | 07:55 PM
contol arms yes tie rod ends no also before I get in trouble it wasn't a recall on the arms either it was a service action the difference between the 2 a recall they have to replace somthing a service action theyonly replace something if something is wrong with that part
Old Jan 11, 2005 | 08:08 PM
CRAZYHAWK's Avatar
You'll have to get an allignment after the replacement.
Old Jan 11, 2005 | 08:21 PM
Jestnomen's Avatar
6th Gear
http://www.audiworld.com/tech/wheel29.shtml
Old Jan 12, 2005 | 12:30 AM
sdaudi's Avatar
yeah the dealership told me about the alignment needed after the job.
thanks jetsnomem for the link to the audiworld article.
i'll try it out this saturday. hopefully the winter storms will leave cali by then.
Old Apr 4, 2007 | 12:41 PM
sbranst's Avatar
Alright, I have attempted a tie rod replacement and ran into an issue. My tie rod required the arm puller for removal, it did not come out easy. The new tie rod does not want to go in, I have tried several angles, wiggling, and adjusted the distance between the lock nut.
Any suggestions for installing the new tie rod?
