Tie rod issues
actually my mate says you can buy the plastic washer that goes in where the ball joint is and that bit unscrews to fit it, never done one like that I normally change the whole thing so new one to me but im sure he is right so ill try to get some information on that
[IMG]local://upfiles/12092/A9A64BF03A3E4D6F91F1564D7FDA3D62.jpg[/IMG]
Alright, I'm guessing that that housing just unscrews like normal? Anything I should watch out for or be careful of when using force to break it loose? I can't mess up the rack or anything else with steering can I? Here is a link to some inner tie rods, there are lots of other sites that have them. I'm just hoping the shop that I got the outers from carry the inners as well.
Also, I've only been working on my drivers side. What are the odds the other inner is bad too??? [:@]
If you notice there is a notch just behind the big nut where the joint is. Hold that with a 22mm (I think thats the size) also make sure you have the wheel turned so that its at its full extension. Then use the good old monkey wrench or 1 1/4 wrench
