Tie Rods or Tie Rod Ends
Old Oct 28, 2006 | 11:34 PM
drewdq's Avatar
Default Tie Rods or Tie Rod Ends
I just replaced the Tie Rod Ends on my 99 A4 (130K miles) because there was a lot of play in my steering. But there is still play in the tie rods, even felt by moving the steering wheel slightly back and forth. Is this play due to the other half of the tie rod (inner), or could it be something else in the steering. I tugged on the inner tie rods when I had the old outer tie rods off, and I couldn't budge it.
My question is, do the inner tie rods wear and if so how would I get them off. They have a nut on the end, but it just spins freely without threading off the inner tie rod. Looks like I need a special huge long socket on there.
Any help is appreciated.
Old Oct 29, 2006 | 03:39 PM
dankhound's Avatar
Default RE: Tie Rods or Tie Rod Ends
Ocassionally the inners go bad, but they arent common. To remove the inners you turn the wheel all the way to the side you are going to replace. Remove the boot and use a large pair of chanel locks to turn the inner tie rod.
Since you couldnt move them they probably arent the issue. Put the front end in the air and turn the wheels from side to side by hand at the wheel and feel for looseness. If theres looseness at the wheel you have either bad inners or a bad rack. If its inners the large "nut" on the inners wont move while outer tie rod is rocked back and forth. If everything is tight on the wheel side, check inside the vehicle. There is a u joint at the firewall that can get loose. There is also the possiblity of something in the collum being loose.
Old Oct 29, 2006 | 05:05 PM
drewdq's Avatar
sweet, thanks man. I'll look into it.
norcal89451
Apr 8, 2013 09:15 AM
copper07
Jan 4, 2012 03:29 PM
Quattro_1.8t
Jan 19, 2008 04:12 PM
skinnyhb
Oct 7, 2007 06:09 AM
